Old 07-18-2024, 06:35 PM   #5
spinjockey
It is definitely broke off a suspension component. It isn’t clear if you were able to look at both ends of the drop links on all four corners. I would pull the wheels on each side and examine closely. Since you haven’t complained too much about handling I suspect it is a drop link as anything else would cause a significant issue. But you shouldn’t drive it until you are confident it’s not a suspension bolt.
spinjockey is online now   Reply With Quote
