Old 07-14-2024, 08:43 AM   #11
jluetjen
Registered Member
Originally Posted by pilot4fn View Post
Sometimes while doing the vacuum bleeding process, the bleed nipple threads leak a bit of air to the bleeding hose - visibly shows that there is air in the system.
I prefer pressure bleeder or other person sitting in the car pressing the clutch pedal for that reason.
True. I'd periodically check for that by applying a vacuum with the bleeder nipple closed. No bubbles. So that kind of eliminates that. Also, when I'd complete the bleed and try the clutch, it wouldn't work.
jluetjen is offline   Reply With Quote
