Thread: DME No power
Old 07-09-2024, 02:40 PM   #19
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Jaybu02 View Post
I did some testing over the weekend. Grounds are all good including one next to dme. Looks like everything is working upto the M525 alarm box. I wonder whether putting in a different ABS pump has upset things? Picture of that wiring would be great. The pump is connected up but not the front abs sensors or brake wear sensors. Thanks for your help, appreciated.
Here's the 535 alarm box from a right hand drive 2003.
Note the [W] pin A23 connects to the DME at pin A3. That is the only connection I see directly to the DME.
I also noticed that D26 on the DME is marked as "Actuation" and connects to the DME Relay [85] through pin 4 of connector X2/3. Do you have power at the relay?
Are you positive that you have a working and matched set of DME + Alarm (Immobilizer) module + key fob transponder?
