Old 07-08-2024, 09:06 PM   #2
spinjockey
Certainly check and refresh the rear main seal if it’s not the updated part. The pilot bearing should come with the clutch kit. I would replace the slave cylinder since it’s a cheap while you’re in there part although you will have to bleed the clutch so there is extra labor cost. I did my clutch then had the master cylinder go out three montgs later so got to do both master/slave. I don’t think it cost me more money net to repair this way but the car was out of service which is annoying. In general the IMS aftermarket bearings gave a lifespan too. I haven’t heard of people servicing their ims more than once in a lifetime but it’s worth considering if yours is one of the early single row bearing replacements. Sone of the aftermarket second generation ims replacements have been improved for longevity..
spinjockey is online now   Reply With Quote
