Old 07-05-2024, 06:06 AM   #2
AK986
Possible, but you will need to run electrical diagnostics to find out.
Yesterday, I did the smoke test, and there were no leaks. I started it from the intake filter, and then separately did from the AOS hose in tot he intake Manifold, directly into the AOS.
While doing that, i saw the power steering reservoir was empty and the drain line was rippled. I installed a new longer line.
I cleaned the MAF sensor again. If it comes up again, then I think it could be the MAF sensor.
P0446 - code came back on again. I'm going to open the canister and see if the value is stuck. I tried the scanner and EVAP does open and close.
P1531 - came back on.
AK986 is offline   Reply With Quote
