Thread: DME No power
Old 07-03-2024, 03:21 AM   #13
tcoradeschi
Registered Member
Originally Posted by Jaybu02 View Post
I took out the wiring loom from my boxer. It has had major water ingress issues and the grounds had been joined up.
I have put in a loom from a MY03 Boxer and had to change the ABS pump. The DME is not getting any power and PIWIS 2 can not communicate with DME.
The airbags are off the car. The cluster comes up with the a lightning circuit symbol failure sign.
Any pointers appreciated.
Would you be able to provide some additional background? I don’t understand what “water ingress issues” are (it’s wire and some connectors), nor what “joined up” means.
When you say “wiring loom”, what, specifically, did you replace?
Was everything working before you did so?
Thanks.
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
