Old 07-02-2024, 03:12 PM   #3
AK986
P 0446 EVAP cannister purge valve below limit, purge air line blocked.
P 1124 & 1126 Fuel air mixture too lean (both banks), possible intake air leak
P 1130 Overly lean condition, intake leak
P 1531 cam timing active, but no positive position (it isn't working) bank 1
Thank you for replying with the feedback.
I ordered a smoke leak detector which should arrive tomorrow. I hope it will resolve for follow 3 codes once i determine where the air leak is at.
I have gotten code P1530 as well, which is short in the wire possibly. Now it's starting with P1531. Do you think it would be short in the wire since the mileage on the car is 38K for the solenoid to go back?
Also, do you recommend anything for check the EVAP value?
AK986 is offline   Reply With Quote
