Old 06-25-2024, 06:33 PM   #5
spinjockey
If I had to do this over again I would have ordered the trim. The tech convinced me that the aftermarket would cover just as well and it does but it’s not the same. I should say I had also done some homework in advance to know that I needed to remove the passenger A pillar cover to disconnect the antenna wire and avoid shearing the wrong part of the antenna wire. The tech did not know this or how to do this even though I explicitly called about this concern.
spinjockey is online now   Reply With Quote
