Old 06-22-2024, 09:57 AM   #1
spinjockey
I just had my windshield replaced too. Satellite did not come with any suitable gasket the first time. The second time they brought a similar gasket but not an exact match. I don’t have gaps but it’s not as flush as the original. The original gasket is a two piece. It is true that you don’t need the gasket to prevent leaks as leaks are prevented by the sealing adhesive but a gap will make it look unfinished. Lots of new cars have moved away from gaskets. You should call them back if you are unsatisfied. Getting oem equivalent gasket is a pain. I couldn’t find any.
spinjockey is online now   Reply With Quote
