Old 06-17-2024, 10:53 AM   #1
redpepperracing
I just watched it as well, even though I've already done it! I wish I had seen it sooner though, as when I was doing the research I did not know about the horn contact piece that you need, so I had to wait for that. I also commented on the video that you can an OEM Porsche the connector for the horn pin if you want to keep from modifying the cable plug. I also bought an offset adaptor so the wheel sits vertically higher, as for me it blocked the cluster too much without it.
You should get a camera/phone mount for making these, then you can use both hands when working, and especially while driving!
redpepperracing is offline   Reply With Quote
