Old 06-15-2024, 09:17 AM   #1
KevinH1990
KevinH1990's Avatar
I had similar symptoms to PLP's. My cruise control stopped working, but the bulb illuminated when I started the car. I traced the problem to fuse B7 which had blown. Since that fuse also controls the brake lights, I'm concerned that the problem could recur and cause a safety issue.
Are there any areas I should check to see what could have caused the fuse to blow? The only work I have done on the car recently is installing a rivnut in the windshield header. (One of the fasteners that holds the center light and associated components had come loose.) This did require that I disconnect the three electrical connectors that feed into the light assembly.
Thanks in advance for any suggestions.
