Old 06-15-2024, 08:59 AM   #7
flmont
( Maybe ) drain the oil,fill engine with a safe solvent or a 50/50 mix pull fuel pump fuse,..crank the engine over drain and repeat,..How much coolant did you add ..? Or if its just a little milky stay with the first suggestion, a couple more oil changes it may clear it up..I feel for you.. good luck Frank
flmont is offline   Reply With Quote
