Old 06-11-2024, 01:13 PM   #2
S50Sinner
Good news is it's not hard to find out. You can test this by lifting the center console out and looking under your shifter. There are a couple good videos on the console removal process, it's pretty easy.
Push and pull on the cables directly, if there's any slop, then you need either cables or a linkage. The shift linkage that you need to look out for is mounted on the outside of the transmission, Tarett makes a replacement/solution if that's worn out. Hopefully, this yields no play and you can solve this with the B.A.D. shifter.
S50Sinner is online now   Reply With Quote
