Old 06-06-2024, 12:38 PM   #12
elav
For those that are considering swapping at top - it is true that a few fasteners on either side hold it in, but also be aware that with at least the 3-bow tops, there is a micro-switch that needs to be disconnected too.
If you are planning on replacing a 3-bow top with the newer 4-bow top, I believe the microswitch is in a different place - so you will need to do some re-wiring. I also believe the convertible top transmissions are also different.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is offline   Reply With Quote
