Old 06-06-2024, 07:04 AM   #2
JFP in PA
Originally Posted by Lacostas View Post
But in any case, shouldn’t the car run fine even when SAI pump is out? Maybe the SAI has locked a valve closed so that the air doesn’t get through?
Nope, the DME would need to be reprogrammed to remove the SAI. You are vainly searching for a cheap,,easy, and quick out, and there isn't one...
