Old 06-03-2024, 09:43 AM   #2
Danimal
I found the side to side play on the 987/997 shifter to be too much. Look up the “alexmod” to see what I’m talking about. Rather than buy an expensive kit like the function first shift right, I decide to go with a Ben’s short shifter and side lever. I think the side lever is key for getting rid of selection slop….otherwise I liked the 997 shifter.
Note that Ben’s short shifter has washers to hold the lever in place where it bolts to the pivot arm. I’ve seen other short shifters that don’t have them and they have slop there, similar to where some of the slop was identified in the “alexmod” video.
I assembled Ben’s shifter last night in a donor assembly and plan to install it in a few days. If all goes well I’ll have a nearly new 997 shifter for sale. Less than 1k miles on it.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
