Old 05-25-2024, 06:40 AM   #1
gumetina
Had a family trouble for a year or so, and the boxster just did not reach the top of my priroty list .
Long story short, it works.
Even had a spin around the block for a few times.
The engine got exchanged for a low miles one that i stumbled upon for cheap, but ... it turned out to have a HG failure, that i discovered after the installation in the car. Now i need to reinstall the old engine i could swore will die during the process , but did not...
Fuel pump died, then a short on the fuel level sensor fried my instrument cluster. Now i am completing a virtual one using realdash app as it turned out to be a cheaper solution then a second hand one.
Also had a fight with stock motronic dme, but eventually i won. Found all the necessary stuff needed to make it run like a dream on a 3.0l engine. Injector constant etc.
Even did a few dyno runs... power wise , nothing spectacular, hoping to touch 200whp.
Will post some pictures and clips later.
P.S. It sounds wicked
gumetina is offline   Reply With Quote
