Old 05-09-2024, 01:53 PM   #10
elgyqc
elgyqc's Avatar
The CEL code I was getting was "P0102 The Mass Airflow Sensor (MAF) Sensor is unplugged, or the wiring is damaged, Loose or corroded electrical terminals in the MAF Sensor circuit, Faulty MAF Sensor".
I ordered a Cardone remanufactured MAF sensor from a popular supplier (only $34.79 US) and, between the rain showers, got into the engine compartment and had a look at the MAF sensor to see what screwdriver I needed... and noticed in passing that nothing was plugged into it. Hmmm that could be the problem. Once the connector was connected I went for a test drive and didn't get a CEL! And had more power. If only all problems were that simple to correct.
Grant
