Old 05-06-2024, 08:27 PM   #6
elgyqc
elgyqc's Avatar
Originally Posted by Danimal View Post
I think I’m going to give them a try. If the pucks compress is there enough thread to tighten them back up? I’m thinking any material (rubber or poly) will compress a bit.
In an emailed from Greg at PRG he mentioned the following:
"There is a crush sleeve, get the bolt tight, about 60lbs. The bolt torque has no relevance on the bushing preload. The bushings are set to a predetermined preload by the length of that sleeve. you could machine a longer or shorter crush sleeve if you wanted to try different settings "
Grant
