Old 05-02-2024, 08:58 AM   #2
redpepperracing
I made a bracket to mount the vacuum reservoir on the block off plate. In terms of the vacuum lines, I just referred to the image that has been posted here, and then just removed the SAI bits. I don't have a picture for that as I'm in the middle of a 996 intake plenum conversion. Refer to the images in this post, and instead of a 3 way at I to G, just go straight from I to F
Here is the bracket I made. I used material I had on hand, otherwise I would have done it a bit differently:
redpepperracing is offline   Reply With Quote
