Old 04-29-2024, 05:51 AM   #2
husker boxster
husker boxster's Avatar
You might get it straightened using a vise. But a replacement isn't that expensive. You'll know a new one is correct while you have to assume you can get your bent one back to original. If it's a bit off, your top travel will be a bit off, which isn't good.
I had to replace an arm on a Wheeler Dealer 09 Box S a few yrs ago. Ordered a new one and put it on. The clamshell wasn't closing properly - it was off just a bit. Took the new rod off and compared it to the opposite side. The rod I didn't replace was bent also. Ordered a 2nd rod, put it on, and the clamshell closed perfectly.
1989 928 S4 5 spd - black
