Old 04-04-2024, 01:59 PM   #10
newBgeek
Originally Posted by Rob175 View Post
OK....I have that tool.....but how do you grip it and turn it....fingertips? If it needs to be attached to something like a wrench, driver etc.....how did you maneuver that?
At first I put it in a small socket but realized I didn't need that. It's easier with just the bit. It's a perfect fit so you can feel it slot into the screw which is slightly recessed. These are tiny set screws so there isn't a lot of torque on them. You can turn it with just your fingers. The important thing is the positive contact. You will struggle to get that positive contact with any other contraption. This was the smallest of my flathead bits. Any bigger won't fit.
Sent from my SM-S921W using Tapatalk
newBgeek is offline   Reply With Quote
