Old 03-30-2024, 06:26 AM   #5
Rob175
Rob175's Avatar
So???? How did it go?
After you finished the job (assuming you did) and looking back on the job, would you advise me to go through the vent or from under the dash?
Another question: IF going through the vent, can you access BOTH set screws or do you need to go below the dash to access the other set screw? (in other words from BOTH positions depending on which set screw)
Ideally it would best to BOTH set screws from the vent but "ideally" isn't always possible.....lol
98' Boxster
Rob175 is offline   Reply With Quote
