Old 03-20-2024, 07:38 PM   #13
elgyqc
elgyqc's Avatar
I'm back at it again, after months of not motivating myself to get out to the garage and get on with the swap I have finally taken a few steps forward. The engine that is coming out is sitting on my latest low-rise dolly on the garage floor and the original engine that is going back in just needs the new RMS installed followed by the flywheel and clutch.
Then I have to pull the outgoing engine from under the car and swap over the alternator and a power steering line as well as the transmission, and make sure nothing else has been forgotten.
The garage is a bit crowded and I can't open the door yet to make space (during the winter I cover the door with styrofoam sheet insulation and seal it with plastic sheeting since the garage is heated by a thermo-pump). So moving around two engines, the engine hoist and the engine stand is a challenge in choreography.
I succeeded in dropping the engine by myself despite a transmission jack that can only briefly hold weight, it needs a rebuild. I think the rebuild will have to be done before trying to reinstall the engine.
Grant
