Old 03-14-2024, 11:48 AM   #18
Gilles
I had use the tip from JFP and it works very well, just get two long bolts with their heads cut off and you should be able to align the tranny properly, you may have to rotate the input shaft a bit to align the input shaft with the clutch splines
