Old 03-10-2024, 12:52 PM   #1
-tWv-
Posting an update here for posterity.
I ended up circling back to this to diagnose this past weekend.
As I stated in my previous post, I removed the pads and the noise was still present. Pointed to either wheel bearing or something with the parking brake.
This time, I then removed the caliper and rotor and spun the hub itself, no noise. Likely not the bearing.
Finally, I cleaned off the inside surface of the rotor the best I could where the parking brake shoes make contact. I also tightened the parking brake sprocket to have the brake shoes sit further away from the ID of the rotor. Put everything back together and no noise!
Final Diagnosis - parking brake shoes scraping against the rotor.
-tWv- is offline   Reply With Quote
