the ebay or amazon resistors for the fans work great and they are only like 10 or 15 bucks, that will probably fix the lack of slow speed on the fan, as for the temp you are seeing they are perfect on or around 180 and 200 when you push seems very normal, if is taking too long to warm up is not restricted it could mean is to un-restricted in other words your thermostat could be staying partially open when cold
