Old 03-05-2024, 10:57 AM   #10
Gilles
David, with 19k miles your clutch disc should be ok, perhaps you want to remove the gearbox and replace the throw out bearing and lube the splines on the shaft, IMHO, there is no reason for it to be too stiff
PS: as a bonus, you would be able to see if the rear main seal is sipping or not.
