Old 03-03-2024, 10:23 AM   #2
JFP in PA
You may not need to replace the actual IMS bearing, but you may want to contact LN and inquire about getting a replacement flange cover. Replacing just the cover requires prepping the car as though you were going to pull the bearing however (engine locked at TDC, cams locked, etc.).
JFP in PA is offline   Reply With Quote
