Old 03-03-2024, 03:50 AM   #1
mach_y
Unhappy 1999 986 - top issue
Hello! I am having an issue with my version A soft top, hoping for some help. My issue is that if I put the top completely up, it then won’t go change direction to be able to close it. The motor sounds like it is trying, but almost like it has a harder and harder time. What seems really odd is the sound seems the same regardless of which direction I push the switch to open or close. So far I have tried the following:
- remove the cables from the drive motor, and using a drill, get it to slowly close each side.
- once I have manually closed it part way, I took off the drive bolts on each transmission, and used the drill to align each transmission on the alignment marks.
- then reinstall the levers and drive bolt, and reinstall the drive cables in the motor.
- at that point, I can use the switch to make the top go in either direction.
- but, if I close the top completely, it does not automatically stop once it gets to the fully closed position, and at that point it is now stuck and won’t open (back to the start of this issue).
So since when the top is not fully opened or closed, the top works as it should, I am guessing that all of these parts are working:
Double relay, transmissions, drive cables, motors, fuses, dash switch, parking brake microswitch.
Could this be caused by one or more of the microswitches on top of the drive motor, in the b pillar, or up front where the latch closes being bad?
Thanks!
mach_y is offline   Reply With Quote
