Old 02-29-2024, 06:21 AM   #5
daver52
Originally Posted by azlvr View Post
Look at the light on dash to see if it’s in manual mode. Sometimes when I’m in manual mode it sometimes goes back to auto mode because console moves a bit. The manual switch is in the selector mechanism. Maybe the switch is bad.
Thanks, I did check this just to be sure and it's in manual mode, isn't bouncing/moving back.
There was an old Wheeler Dealers episode (so old that Edd was the mechanic and they were in England) where Mike bought a 986 w/ Tip. The issue was either the Tip wouldn't shift automatically but would manually or vice versa. The fix was to change the trans fluid. Might want to track down the episode on YouTube and see if it matches your issues. Sorry I don't remember the exact specifics of the show, but it was 12+ yrs ago.
Good luck and welcome.
Thanks for this, will have a look and it might be a good idea to change the fluid regardless!
That's a good question. I had my 98 Tip Tran rebuilt a couple years back... so this is my advice...
Don't disconnect the battery. You MAY/MIGHT/WANT to have the transmission codes read. Now... my trans tanked completely... and there was no way too replicate the problem to reveal codes. I'm just saying.
Next... have a trusted shop read the codes.
I'm thinking it's electrical-associated. You could pull the steering wheel... spends a lot of time hunting. Me, after my experience, would just take it in too have the codes read.
Wish I had more for you.
No worries this is really helpful, thanks very much. I have some local Porsche specialists so see if I can get them to read the codes.
daver52 is online now   Reply With Quote
