Old 02-22-2024, 07:04 AM   #1
elgyqc
elgyqc's Avatar
Originally Posted by Bill Ladd View Post
When I got my 2000s the previous owner had removed the rods to the top but left the ones to the clamshell.
Clamshell works as it should, just have to pause when it’s at full open to either manually open (or close) the top. Then proceed with automatic clamshell closure.
Works just fine that way.
This is what I did also. I can put it down while seated but have to get out to put it up. Likely someone with stronger arms could put it up while seated.
To fixed the pan (I think it is styrofoam not rubber) I used GOOP to glue a piece of flexible plastic over the tears... it is still OK 4 years later.
Grant
