Old 02-21-2024, 10:22 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
It sounds like the issue is either with the microswitch in the latch above the windshield or the top relay. Poke the place where the latch hooks to see if it is not being pushed far enough when you close the top. Sometimes the microswitch comes loose.
It's been a while since I had a manual top, but I'm pretty sure that removing the relay will prevent the windows from partially opening.
