Old 02-19-2024, 05:17 AM   #4
Burg Boxster
Originally Posted by LoneWolfGal View Post
Thanks. That being the case, will the switch's "on" status be deactivated if the hood is closed but not completely latched?
You need to ask Porsche style...
"Will bulb's Off status be Activated if hood is closed but not 100% latched?"
Generally speaking, you are correct by engineering design.
That said, you can always disconnect plug at latch and thus proverbially short circuit if there should be issues w latch switch at that location.
Good luck
"Cool Prius!"
- Nobody
