Old 02-16-2024, 03:41 PM   #3
Pashets
Originally Posted by redpepperracing View Post
This is my goto site for this stuff: https://www.wheel-size.com/calc/?wheel1=205-50-17X7ET55&wheel2=245-40-18X8ET57&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
That link has the specs of what you have on the front versus new, and yes, it looks a 15mm spacer would be ideal, as long as the fender still clears.
Here is the rear link: https://www.wheel-size.com/calc/?wheel1=255-40-17X8.5ET50&wheel2=275-40-18X9ET47&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
It looks like that should work with no spacer.
Thanks a lot! Will go check them out now I think
Pashets is offline   Reply With Quote
