Old 02-10-2024, 12:27 AM   #4
Smallblock454
Just disconnect the starter battery and wait 30 minutes before you start your work and connect it afterwards. Also make shure that you don't have the key in the ignition lock while you disconnect or connect the starter battery.
If you have memory seats, then first remove the 4 screws that hold the seat. And afterwards disconnect the starter battery. Also no key in the igntion lock. Then you can diconnect the seat wiring harness.
