Old 01-31-2024, 08:48 PM   #2
spdrcr21
Originally Posted by flmont View Post
I replaced everything about 2 months ago..easy job...BUT I will caution you on removing the hoses,just my pump was bad and when I was trying to Dis-connect the lines I snapped off the plastic nipple on the fuel sending unit,..So I now have a completely new system Bc I had to replace the sending unit aswell...hardest part for me was seating the new seal...Have fun..
Thanks for the heads up. The hoses were a pain to remove on the sending unit. One of my connectors was bad and would no longer hold onto a nipple. I was able to use a similar Dorman part. It's held up thus far. The seal wasn't too bad. I used a new one and used synthetic grease to lube it.
spdrcr21 is offline   Reply With Quote
