The check valve going into the resonance tube boot is oily on the boot side. The PCV valve is also very wet/oily.
To replace to replace the check valve, is it just press fit?
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
