Old 01-08-2024, 08:46 AM   #10
BruceH
BruceH's Avatar
Originally Posted by KevinH1990 View Post
Woody63 has a 2004 Boxster and BruceH has a 2001. Porsche transitioned to the MOST system for audio sometime after they build my 2000 Boxster. I'm fairly sure that Woody63 has the MOST system in his car and BruceH does not. I don't think Woody63 will be able to replicate BruceH's wiring in his car.
Because I don't have the MOST system in my car, I don't have any direct experience with it. I have seen posts that suggest significant amounts of re-wiring are required to adapt an aftermarket system to a MOST-equipped car. I suggest that you search on the topic, and you should be able to find someone who made the conversion work.
Good luck.
You are correct, I do not have the MOST system but this unit does come with a Canbus box, I am assuming that is what is needed for a MOST system?
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
