Old 12-30-2023, 04:52 PM   #1
JAT
Need help, no acceleration from throttle
Hi, Im new here and I just purchased a 1997 Boxster. It had a vacuum leak that I finally found at the oil fill pipe which had multiple cracks. I ordered a new one and just installed it (BIG PAIN). The problem im having now is that when started car idles fine but does nothing when I press the throttle. The car ran perfect before i replaced the pipe so it has to be something that i did while replacing it. The only thing I had to do to get enough room was remove the pipe from the AOS and I had to remove the secondary air injection pump. Can anyone help me figure out what i did to cause this?
JAT is offline   Reply With Quote
