+1 on getting more detailed information on what happened when the car quit running.
How did you check the battery and determine it was good? A simple voltage test showing 12 V doesn't mean much. Remove the battery and take it to a auto store and have it load tested. Check battery connections for corrosion and make sure they are tight.
Do your lights work when you turn headlights on? What about interior lights?
Report back!
