Old 12-11-2023, 10:15 AM   #2
obthomas
You say your cluster has green and blue connectors and I assume a grey one. You need a cluster with these color plugs. You will also need the cluster to be for the manual transmission. Beyond that it should be plug and play. As for plugs, they are usually available used on Ebay.
Not necessary but a scanner such as Xtool X100 will set the milage to whatever you want and also not necessary an eprom read write can be used to change the VIN .
Good Luck
2003 Boxster S, Chevy LS3.
obthomas is online now   Reply With Quote
