Old 12-09-2023, 04:21 PM   #11
Danimal
Resurrecting an old thread. Has anyone else had this issue and solved it?
I have the exact same problem. I thought it was the short shifter that came with the car so I installed a brand new 987 shifter using the alignment tool. I had the exact same issue connecting the blue cable so I stretched it to fit (about 1/4 inch). It was a little better than before, but still stiff. Wondering if I should break out the dremel tool.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
