Old 11-16-2023, 08:17 PM   #2
exiledrebel
I replaced the original top (plastic window) with an aftermarket top with glass window on my 01 S. I replaced only the top, not the top and frame. There was no need to modify anything to get a good fit. The fit is exactly the same.
The only caveat is that you lose a bit of underhood access when retrofitting a glass window top. It's not a major problem, but you won't get quite as much space for access.
exiledrebel is offline   Reply With Quote
