Old 11-13-2023, 07:31 AM   #1
elav
Originally Posted by Adrnlyn View Post
Just returned from porsche palooza in nw ar. Motel parking lot around my room had 5 911-986 appeared to be early 2000s cars. All of us set off our alarms at some point. Talked to lots of other folks who have the same problem
My car has those fantom alarm issues I have read about. Cant lock/unlock with fob without setting off alarm. Sporadically set off alarm with key lock, unlock. Filler door sticks after alarm issue. first night, locked with key, red light on dash flashed all night. 6:30 am unlocked with key, set alarm off. Quickly put key in ignition and alarm stopped. Hit the dash button, don’t remember if was red. Go to buy gas, can’t get filler door open. Broke replacement filler door cable. Two 911s pull up and tell me to try starting car, did and filler door opened.
I replaced filler door servo last fall. Codes cleared
Been to two different independent Porsche shops, they can’t make fail. No codes. Anyone find a diagnostic decision tree to help find which element is bad? There has to be a fix? Even a proper locking/procedure process, may be something I’m doing.
Want to go to more out of town events but dont feel comfortable with car can’t lock. Not being able to buy gas when 200 miles from home, not good.
Any help appreciated
Lynn
2004 boxster s
Have you replaced the ignition switch? My alarm used to randomly go off all the time (in all states of the car being locked/unlocked). I replaced the ignition switch and and the strange behavior stopped.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
