Old 11-05-2023, 10:37 PM   #35
ike84
1 - no
2 - no
3 - yes
If you want power, you need everything from the box to the TB to be larger. Plenum geometry making more power is bull****************, but needs to be swapped to fit the larger TB.
She won't run without a tune. The ECU won't be able to interpret flow data with a larger maf housing and run lean (detonation lean)
Also, your next project should be to gut the exhaust. Power gains will be muted if she can't exhale.
Sent from my SM-N976V using Tapatalk
