Old 10-30-2023, 01:14 PM   #2
JFP in PA
Originally Posted by kjsisterson View Post
The code is P0343
P0343 Camshaft Position Sensor 1 – Above Limit
Potential causes:
– Short circuit to B+
Check the connector/wiring.
Check signal wire from DME control module, pin III/20, to CMP sensor for short circuit to B+.
1. Connect special tool 9637 to wiring harness (DME control module connector).
2. Remove connector of CMP sensor.
3. Connect voltmeter to special tool 9637, pin III/20, and ground.
Switch on the ignition.
Display: 0 V
If battery voltage is displayed, check wiring harness for chafing and pinching damage.
