Old 10-30-2023, 09:54 AM   #1
stateofidleness
Vaccum Canister replacement and other vacuum stuff
Howdy all - replacing most of the vacuum stuff in my '00 2.7L. I have the passenger intake manifold off already. I'm replacing all the old cracked plastic lines and connectors with brass barbed connectors and 4mm vacuum line.
I have a replacement vacuum canister, but wanted to confirm. Is it just a small phillips screw that holds it in/on?
I noticed the one little plastic line that sorta "wraps around it" (not the one directly connected to the reservoir) is broken in half. I believe that line would go to the electronic changeover valve correct?
Are there any other valves/parts I should replace "while I'm in there" (under the manifold)?
Thanks in advance!
stateofidleness is offline   Reply With Quote
