Old 10-26-2023, 03:17 AM   #3
tcoradeschi
Registered Member
Welcome!
If you google about, there are lots of resources dedicated to Boxster top issues.
What I see is that your clamshell is likely slightly tweaked. You will want to check the stops under that rear edge to make sure that’s not what is causing the issue, and assuming it’s not, then you will likely need to tweak it back in the other direction so that it lays flat.
Does it sit the same way when the top is down?
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
