Old 10-24-2023, 11:26 AM   #8
10/10ths
"50 Years of 550 Spyder"
10/10ths's Avatar
This is explained in….
….your owner’s manual.
It’s all in there.
You bought an exotic car. Take twenty minutes and read the owner’s manual.
The security system goes into a “Deep Sleep” mode after a few days. You need to stick the key into the driver’s door and turn it to the front of the car and then pull it out and hit the “unlock” button.
More fun facts:if you stick the key into the driver’s door lock, and turn it towards the front of the car and hold it there, it will lower both windows.
If you have the top down, you can put the “Red Clip” onto the top latch and lock the car. This will activate the motion detection alarm. If anyone sticks their hand into the cabin, the alarm will go off.
There is a “half moon” cut out in the weather stripping on the bottom of both doors. This allows you to run a battery maintainer into the cigarette lighter plug inside the car to keep the battery charged while it is parked.
Lots of good info inside that owner’s manual.
